HAL509 UA-K
HAL509 UA-K
    TDK(东电化)
    TO226-3
    低功率霍尔效应开关
HAL509 UA-K 数据手册
PRODUCT INFORMATION HAL 15xy Nov/2018 HAL 15xy First ISO 26262 Compliant Low-Power Hall Switch The HAL 15xy family consists of different Hall switches containing a temperaturecompensated Hall plate with active offset compensation and comparator, available optionally with open-drain or current output. As global Hall switch supplier with long-term experience since 1993, 1.5 billion shipped automotive switches and leading expertise in high-quality Hall-effect sensor solutions, TDK-Micronas expands its switch portfolio with the new HAL 15xy family. All CMOS wafer processing is done in TDK-Micronas’ facilities in Freiburg (Germany) to ensure best quality control and highest flexibility. With different switching-point versions, the HAL 15xy switch family serves a broad variety of automotive and industrial applications under harsh temperature conditions. HAL 15xy fulfills the latest quality and functional safety standards as AEC-Q100 qualified and ISO 26262 ASIL ready device, enabling our customers to target even the most safety-critical applications. Features ◆ Sampling and output refresh time of 2 s ◆ 3-wire version with a short-circuit protected open-drain output ◆ 2-wire version with current output As improved successor of the well-known HAL 5xy family, the HAL 15xy is available as 3-wire version with short-circuit protected open-drain output and 2-wire version with current output. HAL 15xy is available in the smallest SOT23 as well as TO92UA package and provides lowest power consumption, fast response times, and special safety features like a unique power-on selftest for greater customer benefit at an excellent price-performance ratio. ◆ Low current consumption of typ. 1.6 mA ◆ Wide supply voltage operation from 2.7 V to 24 V ◆ Overvoltage protection capability up to 40 V ◆ Available in the small SOT23 and TO92UA package ◆ High HBM ESD performance of up to 8 kV ◆ Reverse-voltage protection at supply pin ◆ Operating with static and dynamic magnetic fields up to 12 kHz with low output jitter. Customized versions are possible up to 93 kHz. ◆ AEC-Q100 qualification ◆ ASIL A ready device (SPFM 60%) ◆ Additional diagnostic features e.g.: – Power on self-test (signal path test and wire-break detection) – Monitoring of internal bias and current levels – Overtemperature protection – Output current limitation – Defined fail safe state ◆ Wide junction temperature range from  40 °C to 170 °C, specially designed for operation in harsh environments ◆ High robustness of magnetic characteristics against mechanical stress ◆ Broad portfolio of temperature-compensated constant switching points PRODUCT INFORMATION HAL 15xy Major Applications Our new switch family HAL 15xy is the optimal system solution for key applications such as: ◆ Position detection e.g. for seat belt and gear shift Nov/2018 Available Types and Behavior Version 3-wire ◆ Index counting e.g. for window lift ◆ Brushless DC motor commutation e.g. for pumps and fans 2-wire System Architecture HAL 15xy sensors are monolithic integrated circuits which switch in response to magnetic fields. If a magnetic field with flux lines perpendicular to the sensitive area is applied to the sensor, the biased Hall plate forces a Hall voltage proportional to this field. The Hall voltage is compared with the actual threshold level in the comparator. If the magnetic field exceeds the threshold levels, the output stage (open drain output for 3-wire devices or current source for 2-wire devices) is switched to the appropriate state. Type Switching Behavior Switching Points (typ.) Temp. 2-Wire PreBOFF [mT] Coefficient ISUPlow decessor [mA] [ppm/K] BON [mT] HAL1501 bipolar 0.4 –0.4 0 – HAL501 HAL1502 latching 2.5 –2.5 –1000 – HAL502 HAL1503 unipolar 5.5 3.7 –1000 – HAL506 HAL1504 latching 7.6 –7.6 –1200 – HAL503 HAL1505 latching 13.5 –13.5 –1200 – HAL505 HAL1506 unipolar 18.9 17.3 –1200 – HAL508 HAL1507 unipolar 28.2 23.9 –300 – HAL509 HAL1508 unipolar –5.5 –3.7 –1000 – HAL549 HAL1509 unipolar inverted 3.7 5.5 –1000 – HAL516 HAL1510 unipolar 12 7 –1200 – HAL504 HAL1561 latching 4 –4 0 5 to 7 HAL575 HAL1562 latching 12 –12 0 5 to 7 HAL579 HAL1563 unipolar inverted 7.6 9.4 0 5 to 7 HAL584 HAL1564 unipolar inverted 4.1 6 –1000 2 to 5 HAL566 HAL1565 unipolar 6 4.1 –1000 2 to 5 HAL556 HAL1566 unipolar 9.4 7.6 0 5 to 7 HAL574 VSUP Reverse Voltage & ESD Protection Temperature Dependent Bias Hall Plate Switch Point & Hysteresis Control Comparator Filter The built-in hysteresis eliminates oscillation and provides switching behavior of the output without toggling. Magnetic offset caused by mechanical stress is compensated by using the “switching offset compensation technique”. Current Source (2-wire version) OUT Output (3-wire version) Functional Safety Features The device is able to withstand a maximum supply voltage of 24 V for unlimited time and features overvoltage capability up to 40 V load dump. Overtemperature Protection GND Fig. 1: Block diagram of the HAL 15xy All information and data contained in this product information are without any commitment, are not to be considered as an offer for conclusion of a contract, nor shall they be construed as to create any liability. Product or development sample availability and delivery are exclusively subject to our respective order confirmation form. By this publication, TDK-Micronas GmbH does not assume responsibility for patent infringements or other rights of third parties which may result from its use. No part of this publication may be reproduced, photocopied, stored on a retrieval system, or transmitted without the express written consent of TDK-Micronas GmbH.  Edition Nov. 8, 2018; Order No. PI000148_005EN TDK-Micronas GmbH Hans-Bunte-Strasse 19D-79108 Freiburg (Germany)P.O. Box 840D-79008 Freiburg (Germany) Tel. +49-761-517-0Fax +49-761-517-2174www.micronas.com
HAL509 UA-K 价格&库存
很抱歉,暂时无法提供与“HAL509 UA-K”相匹配的价格&库存,您可以联系我们找货
HAL509 UA-K
  • 2000+3.485762000+0.45182
